One down; We broke the key way that holds the oil pump to the cam shaft. The motor did not seize. I can't spell! Anyone know best case senerio for parts replacemant? Oil, pump, cam shaft, seals?<br /><br />Next motor; taping loudly, no lights, sounds major but the motor has full power. It is worse with a load, but can be heard at idle. With the motor out of gear, and gased, the prop is sleepy and moves enough to push the boat. I disconected the shift cable. The boat's in the water. I guess I need to check the prop for nuetral (duh), but the shift lever is sitting on the neutral switch and I can get forward, reverse, and nuetral. It sounds bad. How can I manualy test the oil pressure. Any ideas about this terrible tapping, clacking, noise?
