tinytanic1
Thread starter- Joined
- Aug 7, 2007
- 13
I have a 1977 Mercruiser 120hp with a 2bbl rochester carb. At the base of the carb. are two adj. screws. I know one is the idle adj., and I assume the other is idle mixture. First question....... is the forward screw idle, and aft screw mixture, or vise versa. Second question is what should initial settings be? My Merc. manual says idle screw should be 1 1/4 turns out, but doesn't show or suggest setting for the second screw.
Also I couldn't get engine started so I reset timing and points to specs, and was getting strong spark. However compression check showed #2 and #3 piston only getting 50lbs, while #1 and #4 were 145lbs. I took valve cover off and found most of the push rods were bent. Would installing new pushrods be good enough to get compression back or do I also need to dig deeper into lifters???????
Engine only has 20.3hrs since complete rebuild, so I know rings and cam are good.
