carb adjustment
cgirard
I recently purchased a 1999 40 HP Merc. Before I put it in the water I added a can of Sea Foam filled the tank with gas, changed plugs and fuel filter. The motor runs fine above 1200 RPM but stalls at idle. To re-start I have to advance the throttle and choke it a little. What adjustments do I need to make what carb adjustment screws need to be turned and which way.
Thanks in advance for your help
j_martin
Re: carb adjustment
How much SeaFoam did you add to how much gas?
John
cgirard
Re: carb adjustment
John, Thanks for responding. One can of Sea Foam to 18 gallons of gas
