carb adjustment
civicsi1279
i have the 2barrel carb on a 170 3.7 which is an 85. what is the spec on adjusting the air mixture screw. thanks
abj87
Re: carb adjustment
I ajust all my carbs till i get the highest speed at idle then a 1/8 turn out from there (1/8 turn richer). Then reajust the idle speed screw back to spec. your going to want to do this adjustment in gear.
if your getting a poor idle you might want to clean out the carb first. because even the newest 470s are 20 years old now.
