ledzeppelin135
Thread starter- Joined
- Jul 27, 2011
- 129
Hello, I recently rebuilt the fuel pumps on my 83 merc 50hp because you could watch the fuel level drop through the fuel filter. I assembled it all and it seemed to be corrected until I was out at the lake and I hit a descent size wave and it lost fuel pressure and I could only go to about 2500 rpm before it would start to bog out. The fuel level in the filter was very low and even if I pumped the bulb it would not help the rpms get back up. I took the carbs off and noticed that the fuel pumps I installed were correct but one screw on each pump was somewhat loose as I could not get to them to torque them down. Also, I noticed on the fuel lines that the ties holding them together were very loose so I got some hose clamps to torque those lines down to get them tighter. I am not sure if this sounds like it could be some sort of an air leak or something.
Also, I am wanting to check the two measurements for the floats to make sure they are set and I am wondering if somebody can explain what I measure and where I measure from. My repair manual is making no sense to me.
Thank you,
-Chris
Thank you,
-Chris
