carb help
pdl
1985 evinrude 40hp i don't see any way to idle this motor down it is idling a little to high to shift in to gear thanks for any help.
pdl
Re: carb help
i don't have a manual yet just got this motor a couple of days a go i had to clean both carbs to get it to run i have ordered 2 kits and i'm going to rebuild them tomorrow.can you explain sinc & link.i've only ran it in the yard it seems to running good other than the high idle problem.thanks
JB
Re: carb help
The linkage and synchronization procedure differs a little from model to model, pdl. It sets up the throttle linkage to synchronize with the ignition advance mechanics.
It is explained in detail in the OEM Service Manual available here at iboats.
Be sure that you make the adjustments with the engine in the water and under load where it asks for that. If you set the idle without a load on the prop and backpressure on the exhaust you will get a lousy idling engine on the water.
