Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
Where is the ice forming?
I have run o/b's from the high 90 degree range to well below freezing, and never had this happen or even heard of it happening.
Never, you'd think have a cowl on with the 120F+ temp of a powerhead would keep things nice and warm in there. It has to do with temp and humidity but normally at much lower temperatures than 70+F.
Question- has that motor got an airbox on it still?
Did you just get the motor or have you had it for a while, when did it start doing it. When you rebuilt the carb did you put in a kit, pop out welch plugs, soak it and such. When I think of carb freezing I think or artic cat skidoo's and Cessena's. The Florida boys on the forum seem to have the issue too, maybe they have a cure.
i never thought anything of it. it doesnt affect the performance and i never get ice just water that condenses because it is cold around the carb body.
it is 100% normal, the flow of air cools the carb, high humidity, creates condensation, freezes on cold carb. i have had it happen even here in Florida.
This is a first Ive ever heard of this. Im interested in reading more about the why's and hows. Maybe you should take a temp gun with you and see what the temp around the carbs are.
I had that happen once. I had problems with my starter rope on my 1955 25hp johnson. I took the cover off to take off the manual starter and after
starting it with the rope I headed back with the cover off and I actually watched the carb as it froze up but that was in 30 degree weather during hunting season/
