freebayliner 85
Thread starter- Joined
- Jan 17, 2009
- 25
I have an 50hp with an enging that would stall at off idle. replaced fuel lines and fuel pump and rebuilt carb. stiil would stall at idle. started motor and sparayed fuel in carb found could get motor pass idle to wide open throtle. after inspecting found fuel bulb was filled so looked at jet. When looking at jet saw hole was too small. Looked at air bleed jet it was alot larger hole. Both jets are the same thread pitch so iI swaped them. The motor runs great!!!!!!!!!!!!!!!!!!! I did not touch the jets when I rebuilt it, but know last owner tried to rebuild carb and he probaly did. I just wanted to post this so if any one else has the same problem they should look at jets to make sure they are in right place.
