Carb Model number for 470 ?
mr 88
Rebuilding my 470 2 barrel.I picked up a 4 barrel intake manifold for it. Need to know the Rochester model number. Would also like opinions on other carbs vs the stock carb, [like a Holly].Also are the cfm ratings the same for the 470 - would a 650 vs 750 make any difference ? Is there anything else needed to go from 2 barrel to 4 besides gaskets ? Any other input on bumping her up to 188 hp is welcome,thxs.
wca_tim
Re: Carb Model number for 470 ?
I would run an edelbrock 600 cfm (1409) marine carb...
mr 88
When I posted the manifold was in transit,ended up two barrel,sent it back and seller found correct manifold, I asked about carbs and 140$ later [manifold and carb] it's at my door with 4 barrel still attached to manifold from donor block.Will keep your suggestion filed away,in case I have any issues.
