orlandoclippertim
- Joined
- Jun 2, 2011
- 106
I think I got my carb kit in..... but I noticed they only gave me 1 packing squishy thing for the needle packing---
and what they did give me was way too big. So I got creative and tried using some fuel injection O-Rings.
(1/4 by 3/8 by 1/16) They may seal OK but I wont be able to tighten up the gland like if it was the proper material.
Are there alternative packing materials ? Like water pump packing cord/string ?
Also---- on the adjustment that has the little threaded aluminum cylinder on the stem---- I only put an o-ring
on the outer side of the cylinder ….. should it have a seal on both sides ?
I couldn't turn the aluminum cylinder on the shaft with my fingers---- so what the heck is it doing? If I turn the
inner shaft the tip of the needle wont be moving in or out..... Is the cylinder supposed to remain stationary when you turn
the inner shaft ?
the picture in the carb kit was pretty much useless...…. and too generic anyway.
Tim
the inner shaft ?
Tim
