wolfie-uk
Thread starter- Joined
- Dec 8, 2008
- 122
hi, got a 58 seahorse, Model:QD19 serial: B2477, have replaced coils, checked water pump etc all the normal things you do to a old engine when you get it, including altering from the pressure cruis-aday tank system to a suction line ( a tank over here is impossible to source )
She starts and runs, but need advice on basic slow and fast jet screw settings before i strip carb so when i reassemble i have a starting point to then fine tune the carb to suit, also what mixture should it be run on? as i have seen several conflicting forums going from 16:1 through to 50:1 oil ratio,
regards
Neal
regards
Neal
