carb or air trouble on a 56 johnson motor
hi_c50
my motor starts fine when i take out the Air silencer body and loading
tube and it takes along time to start if the silencer body is on and sometimes dies out. It seems like its not getting enough air. Does anyone know what might be wrong. What can i do....i need help t hanks
Mas
Re: carb or air trouble on a 56 johnson motor
Sounds like you got a gummed up carb. When was the last time is was cleaned of all varnish?
MAS
freddyray21
agreed either a gummed up carb or a wasp nest in the silencer. run water through the silencer and see.
hi_c50
i just recently rebuild my carb, and tune up my motor. And now its giving me this new problem. I will try to wash my silencer out with water and see if thats problem.
thanks alot guys
tashasdaddy
carb adjustments in the TOP SECRET file.
Chinewalker
I agree - sounds like someone from the rodent or insect world found your silencer hospitable...
- SCott
hi_c50
just check my silencer out today and its clean. I open it and wash it throughly with a water hose but havent try starting it. But the glass under the carb has particles in it. But i just recenlty rebuild my carb! Is my gas tank dirty or is there something im over looking.
Chinewalker
Particles are not good - is the tank clean? They're relatively easy to clean as you can remove the top canister assembly and scrub by hand if necessary...
- Scott
wbeaton
How are the coils in your motor? Have they been replaced?
hi_c50
my coils, points and condesors are all brand new. I replace them when i was rebuilding my carb. I also have a pressure tank whiich im not familar of taking it apart and clean it. Any ideas guys?
hi_c50
i havent replace my fuel line though. All i did was cut off the excess were it was wearing and tearing away only.
