Hi, I recently bought an '87 Yamaha Outboard 200hp ETLH. I've been running through the boat and motor checking everything since the boat has been sitting up for 2 yrs. New spark plugs,water pump, 3 new batteries later, a new problem presents itself. All 3 carbs have a certain piece broken on them(which i noticed when i disassembled them to clean). One of the previous owners tried to glue some sheet metal over the gaps where the pieces are missing. Im assuming this is causing my engine to not run w/out starter fluid( was able to get it running, but had to keep my foot in it, and it died whenever i put it in gear) >.< At first, i was planning on trying to just get the broken part, then it occurred to me that if they tampered w/ that no tellin what else they screwed up, so maybe 3 new carbs is best option. I'd like some feedback on what you guys would do. Also, if this particular carb is a hard one to get, would it be possible to get a carb from another model/engine to fit and run right? ( I found the part on a couple sites, but they are on back order, and $341.00 each=$1023 total >.< HELP
Thanks in advance for any advice!
-Andy
-Andy
