renegade15
Thread starter- Joined
- Mar 29, 2009
- 99
1990 Johnson 70 hp, vro disconnected, using premix-50:1
Symptoms are that it starts and idles fine, upon throttling up the engine starts to do what feels like a violent miss. I explained this to dealer they said sounds lean, rebuild carbs. If I throttle back and turn the engine off then back on it runs fine and will do so as long as it is still warm.
I started the cleaning/rebuilding process and damaged the bottom carb orifice plug as it is in very tight. I am soaking in pb blaster to try to loosen it. I figure I'll have to get a new one of those so when I look online I discover that the one spec'd is 52d, the middle and top carb both have 63d. I've verified this with the dealer. I'm thinking there might be something else going on here.
I bought this boat about 1.5 years ago and it ran fine till this past december. I use it about once a month for a day of fishing on the flats around Tampa Bay.
I will check compression tonight and report back, but figured I'd get a few other things to look at from you-all as well.
Thanks!
Thanks!
