Re: Carb rebuild kit
Have you check the fuel pump diaphram? The problem with the carbs is find someone that can locate the correct needle and seat. The all steel needle seat is pressed into the carb body, you screw a sheet metal screw into the seat and pry the seat out with a screwdriver, VERY EASY TO BREAK the carb body, should use a small slide hammer to remove seat, tap new seat in place with small hammer. You will not know which seat the carb has until you open the carb, and some carbs have been patched by putting needle with rubber tip in seat that calls for a steel needle.
