carb rebuild question
fishing dad 2011
Going to be rebuilding my carb on mon. or tues. as soon as my kit get here..when replacing the gaskets do I use any type of adhesive or just stick em on and bolt em down? This is a johnson 33hp electric.. any hints advice etc. greatly appreciated..:confused:
I am such a newbie it is not funny
mark1961
Ensign
Re: carb rebuild question
No adhesive or sealant is necessary on any of the carb gaskets.....
When you are disassembling, leave the throttle and choke butterflys in the main housing and soak in cleaner.
Monte1961
Just make sure you remove all core/welch plugs pryor to soak. no sealant required on gaskets. after new core plugs are installed, I recommend that you put some fingernail polish on the edges or even some OEM sealant. Only snug new parts! No need to try and break screws. Post back and good luck.
fishing dad 2011
well carb rebuild didnt help my issues I guess I will just junk this motor because it has pissed me off enough.
old boat 54
fishing dad ... you cant junk the motor, how ya take the kids fishing.
Not sure if this will help you. I have a 1966 33 hp electric start also. Engine would start and die out in 5 seconds. Carb has a little gas come out of the air intake. I rebuilt carb, needle and seat were probably the problem. It started up fine with no more flooding. now working on some other issues. One at a time.
I know carb is a pain to bolt on, as studs on engine dont allow much room to get those nuts started. dont give up now.
What Daviet said: "whats it doin ? "
fishing dad 2011
starts and idols fine just will not run high speed worth a crap..I was doing like 6.7 mph on my gps at w.o.t
lindy46
Does it sound like it's revving up properly but not going anywhere? If so, you most likely have a spun hub on the prop. If it's just not developing any rpm's, you're probably running on one cylinder. Also, have you checked compression?
nwcove
i agree with all the advice that was given! dont give up on yer motor.....it sounds like its as simple as a cracked fuel line or your tank isnt allowing air to come in. ive seen so many motors given up for dead, when its only the simplest thing thats causing all the grief. a few bucks for the things you dont think will cause probs, will pay off in the end.
fishing dad 2011
thanks anyways guys just sold it to a guy for 150.00 guess I will just run my merc.50 hp
glengold
probably just needed a good decarb. I just did a decarb on a 55 I have and now I need to buy a higher pitched prop. Its like I have a whole new motor, turns over 6 grand. 10 bucks worth of seafoam. maybe you can sell me that merc 50 for 150 bucks when you get frustrated with it!!!
fishing dad 2011
Or maybey you can just s**k it... Glenard...I have had a hrd enough time with this engine I dont need any BS from you...go give yourself a good decarb.. Seafoam is good for the colon...
glengold
Sorry for your hardships daddy-o!!! At least you had a backup motor..... I don't have that option so I work my ***** off to get the one I have working properly. Next time don't give up so easily, on second thought, that's why there are some good deals on ebay and craigslist...
glengold
and don't ask for help in the future.
