Carb rebuild time
svb165
And I am getting lost in process of locating and ordering the RIGHT kit.
its a Rochester 2 jet mcm 120/140 1351-8480
Does any one know what the sierra # is ??
svb165
Re: Carb rebuild time
I have tried to find the right listing for an hour and a half. found everything BUT the carb rebuild kit for that carb. any one???
airshot
I bought mine from our local mercruiser dealer that way I knew I had the right one. Just took the numbers off the little metal tag and
bingo he handed me the correct kit.
My research says the Sierra kit number is 18-7746 and Napa kit is 18-7097
svb165
Where were you able to find that number if you dont mind me asking.
i can find a kit through a couple of carb shops but useing there numbers no sierra #s
mikecrof
I agree with AllDodge, that Sierra kit says replaces 823427A1. Which was the kit my dealer just ordered for my rebuild of a 2B Rochester and he asked a service guy who said that is the kit they use on all 2B Rochester's regardless of model. The photo looks like it has all the same fiddly-bits that come in my Quicksilver 823427A1 kit.
Any FYI, the power piston does come out, it may have been staked in pretty hard, so it could take a fair amount of messing with to get it to release. I had to use a fair amount of 3-in-1, carb cleaner, and a little bit of pressure using a deep well socket over the shaft and spring so I could gently pry on the flat plate that touches the power nozzle, to get the piston out.
svb165
Thanks guys.
i nailed it down last night too. i couldnt locate a sierra listing for carb kits for some time.
i figured it was pretty standard for a Rochester 2 jet but want to be sure. There are a couple others available.
