carb? reed? whats the problem?
elevationzero000
I have an older Suzuki 6hp. the carb is brand new. i pulled the reeds and they looked fine in my non-mechanic opinion. the engine runs when it is choked half way but dies when it is not choked. it must be something simple. any ideas? thanks!
Knightgang
Re: carb? reed? whats the problem?
Sounds like fuel restiction and running to lean. Check your fuel lines for free flow. Also, are you sure the carb is adjusted correctly? Might be just a setting on the carb is wrong. Do you have your manual? Should tell you how to set all of the jet, mix and idle screws...
