Re: carb removal instructions?
Well, yes. But let's don't over simplifly here. That nut is tight!!!. And yes, it is lefty loosey, righty tighty. You will need a suitable 3-bolt puller with Grade-8 bolts to get the flywheel off the tapered shaft. And it will be very hard to break free.
When you put it back on, the tapers on the shaft and flywheel MUST be clean and dry, and you absolutely MUST use a torque wrench to tighten the nut to 100-105 foot pounds. Ignoring this advice will destroy the motor. I tossed one in the trash just yesterday for that very reason (wasn't me that did it).
Ain't as easy as everybody thinks, huh? Hey, all it takes is proper knowledge and the proper tools and it is a piece of cake. I've done literally thousands of them.
