robinsbd
Thread starter- Joined
- Dec 7, 2013
- 138
I'm looking into replacing my carb, and I came across a carb that says it replaces the Mercarb part number 3310-864943A01
This one says it is a 2 barrel for the 1998 and newer 5.7L. From that description, I am assuming this carb won't work on my 1997 5.7L. Has anyone used this on a pre-1998 engine like mine? The only reason I like this part is because you can get it brand new.
My engine is supposed to have the 3310-807312A1. I have not found any new replacements yet for this part. I have seen rebuilds and remans, but nothing brand new. Is there any place that makes a new 807312A1?
On the other hand, is there any real issue just buying a rebuilt unit? After discussing with a friend of mine that works on hot rod cars, he felt that a lot of rebuilds don't do anything with the cam shafts and that over time these wear and create vacuum leaks. I'm not sure how much of an issue this on boats.
Thanks!
Thanks!
