imported_Bluefin
Thread starter- Joined
- Jun 28, 2006
- 21
I am just wondering if someone on the board could tell me how to synch the carb's on a 1992 50hp 3cyl 2 stroke? It just doesn't want to idle down very well for trolling. Thanks
I agree with Admiral Roscoe, from recent experience. Rough idle, rough running at low speeds. Bought the manual for my motor and also got some good advice here. Making adjustments alone to the carbs did not do it for me. Nor did carb cleaners, not even a great product like Sea Foam. I ended up taking the same carbs you have off, doing a one day soak in carb cleaner, found some dirty jets along with a dirty needle and seat. (make sure those jets are all clear) Could not have gotten the results without the steps Roscoe suggests. He's likely given the same advice many times, and I'm walking (boating) proof that there is no substitute for bench cleaning. The cleaning and rebuilding (which was very easy, given how simple these particular carbs are) made all the difference. Setting a clean or rebuilt carb is easier as well, because it responds as it was designed to. Trying to cure a performance problem by turning screws when we don't know the last time the carb was apart and cleaned will only frustrate you as it did me. Hope you don't mind me elaborating.roscoe said:Best bet is to buy a good repair manual, Clymer or factory.
Might want to rebuild them while you are at it, so you only have to do it once.
Bluefin said:.... but when I idle it down for trolling it just doesn't seem to be running just right. Thanks
