Re: Carb trouble - '83 Johnson 140hp...please help!!
Hey Ohyeah.<br /><br />First thing you gotta do is buy a manual. It is going to have step by step instructions on how to remove, clean, reinstall your carbs (and waterpump, and.....). Best $30-$40 you'll ever spend.<br /><br />Having said that, doing the carbs and waterpump yourself isn't that difficult. Rebuilding the carbs just involves replacing a few gaskets and other parts while you have it apart for cleaning. You can buy a carb kit with all the necessary items at any dealer. I would guess they would be about $15-$20 per kit. You'll need one kit for each carb. <br /><br />Additionally you'll need some carb cleaner. Comes in both an aerosol and dipping format. Either will work, however I think most think the dipping method works best for metal carbs (don't dip any plastic parts or they might disappear on you!). I saw a recommendation for "Berryman's" brand carb cleaner on a post earlier today. Doing a search on "Carb Cleaner" (see red SEARCH function at top of page) will probably provide a bunch of suggestions re brands.<br /><br />Hope that helps. Good luck!<br /><br />Brew
