gonefishin485
Thread starter- Joined
- Jun 29, 2008
- 108
so i took my boat to the launch today, i rebuilt the carbs earlier this week, and after a little tweaking and sealing of leaks at the dock, she runs smooth, banging good on all 4
but i find it idles pretty high just sitting in neutral. when i drop it into gear, the idle goes down with the load on the motor, it runs good thru the rpm range to wot, but when i go back to neutral it just seems like an abnormally high idle.
when i rebuilt the carbs i set the fuel air mix screw at 2 turns out and the throttle cable is adjusted to where the control bar is as low throttle it can get, i noticed if i pulled the advance rod towards the front of the motor, it would idle down nicely, but when i let it go, goes right back to a high idle
so whats wrong? is it running too lean? how do i idle it down some? or should i? should i just leave it? am i paranoid? am i asking too many questions? anybody got any suggestions? do i need to post pictures? would a video help?
