Re: carb vacum leak on 5.5 what to do?
wbeaten,
that is correct. the carb will not seat all the way flush against the manifold. when the bolts are tightend (2) the carb has a small gap between the manifold. small space, maybe .05 or so. just enough to allow some air into the fuel mix.
the motor runs great at higher rpms, but when throttled down to slow speed, it stalls and dies, and runs semi rough. the slow idle doesnt quite run like a sewing machine. as stated earlier, i shoot some carb cleaner and it stalls.
in the throttle position, high is great, shift is pretty good, anything lower and she stalls.
