I get that, but I am concerned that the pump is working intermittently. I have had this same problem for a looooong time. My boat will run fine for a long time then all of the sudden I can't get it to run at 3500 RPMs, just idle. I thought it was the old carburetor I had on there. So I took the old Rochester carb out and put a rebuilt Edelbrock 1409 in and it ran great for 3 trips, but on the fourth trip I got the same problem I got with the Rochester. The Rochester was always hard starting it took lots of cranking (coil spring choke). The Edelbrock (electric choke) always fired up right away until the fourth trip it took tons of cranking like with the Rochester and it was also that fourth trip that it didnt want to run properly...
Additionally, I am not sure if the fuel pump is the original fuel pump that came with the boat from 1979, or if it was replaced in the rebuild 4ish years ago. I'm thinking it is the original since it definitely had the original glass indicator and it had a tiny label playe of it with a serial number that led to nothing when I put it into Google
