ledzeppelin135
- Joined
- Jul 27, 2011
- 129
Hello,
I recently decarbed my 83 merc 50hp by soaking the pistons overnight and then heading to the lake and spraying deep creep in the carbs till it dies twice and then running wot. I then replaced the plugs and then tore down and cleaned the carbs and switched over to synthetic oil and just today adjusted the idle mixture. I took out the plugs to inspect the carbon buildup and was astonished as to how much carbon was on the plugs already. It seems that there is a little less buildup on the piston tops but the plugs are completely covered, it seems even more so than the old plugs I took out. I am wondering if these plugs look normal for a two stroke, and if not what could be causing this. At a very low forward speed, the motor does shake very bad but I have it pretty dialed in to where it runs smooth at idle and wot and no hesitation when the throttle is punched. Do I need to decarb it a bunch more times or do something different? Please let me know,
Thanks
guys
Thanks
guys
