Re: Carbs cleaning question
I have rebuilt countless carbs and unless the carbs were beyond belief in dirt,I didnt remove the core plugs,Your carbs appear cleaner than some Ive done without removal.You should remove all plastic and rubber,get a carb solution bought at local auto store and soak the carbs at least a few hrs.i then soak in hot water with dis washing soap,then run hose for rinse ,get a can of aerosol carb cleaner,if you have compressed air,blow dry with all passages getting a good blast,follow with the carb spray,you can likely reuse the float,but I like to change the needle ans seat ,the seat will unscrew,the bottom part of the carb has 2 brass plugs,behind the pluge ,inside the bowl are jets that are screwed into the casting,you need a screwdriver that is small but the head of the blade needs to be thicker than a normal screwdriver that size is.There is a special jet driver for removal,but grinding a small driver down and grinding blade til it becomes thicker will do it.That said,iff you take a pipe cleaner ,you can clean the jest while in place if removal just dont work out,holding up to a lite should let you see if passages are clean,if your gaskets seem ok,you can reuse them,the newrnes are rubber and allow for reuse
