jerryjerry05
- Joined
- May 7, 2008
- 18,186
Is the idle tube loose? No? then I wouldn't worry about it.
The pic shows foam floats, they don't usually go bad unless
someone has hit them with something that melts the foam.
The position of the float when the carb is upside down should be level
with the body of the carb.
The drop (float) should almost touch the center post when the carb is righted.
