Re: Carbs leaking oil and gas mixture
If you're taking them off anyway, go ahead and buy the parts kit for the rebuild. You get new floats, needle and seats and all new gaskets. Once you have them off, disassemble them and soak them for awhile in carb cleaner (assuming you don't have plastic-bodied carbs). Put the new parts/gaskets in and you should be golden. Not a difficult job.
If you do have plastic carbs/plastic float bowls, be sure to check if the float bowls are warped and not making a good seal.
