carbs on 70 hp evinrude
billy davis
gas running out of all 3 carbs on 70 hp evinrude when you try to start it. once it starts gas quits running out. runs good when it starts up.
SparkieBoat
Re: carbs on 70 hp evinrude
needle valves need to be replaced ..and clean carbs and check float adjustment
billy davis
thanks for the help. i will take carbs back off tomorrow and put a hose on it and blow in it like you suggested thats a great tip. thanks again.
billy davis
took the carbs off. the needle jets were not closeing cleaned and reinstalled they work now. the hose trick was great. THANKS AGAIN
