Carburator Screws
Johndeere101
I was looking over my mid 80s johnson 50horse motor that i just picked up today and found that there was a carburator adjustment screw missing. Could anyone tell me what this screw controls its at the back of the carb where the air is drawn in, its brass and has no spring. If i can find a replacment screw, how many turns am i supposed to turn it in? Thanks in advance for any help here.
OBJ
Re: Carburator Screws
Welcome Glastron!<br /><br />Take a flashlite and take a look in the hole. If you see a jet in there, it's just a plug screw that's missing. You might even find it laying in the pan somewhere. If it's not there, the replacement PN is 317501. There's a little oring that goes on the plug to...PN 321117. You can get these from any John/Rude dealer....but take a good look around the pan first.<br /><br />The plug just screws in snug.
Johndeere101
Thanks for the help, but you see i removed the other brass screw and its a needle valve screw. and it has no o ring on it just a pointed screw. Do you know what this controls? mixture? idle?
OBJ
Yep...controls the idle. Don't think the mid 80's 50hp had low end needles. Looking at the parts thingy, needles came back around 89'. So...if you could post the model number, we can tell ya' the year and PN for the needle.<br /><br />Did ya' look in the engine pan yet?
Johndeere101
Well the model number on the motor is 50ESL74M. Can you tell me what year it is? I took a good look around for that screw in the pan but couldnt find it so am i able to order just this screw for it?
OBJ
Your engine is a 74' Glastron. The needle part number (newest) is 431632. You can get a parts break down of the carb by going to www.evinrude.com/en-US/. Look in the lower left corner for diagrams and follow the instructions. Should help you out.
