Carburetor corrosion
buba
Hi
I live in Brazil and I use a Yamaha F15AMHS outboard, purchased in Nov 2004, model 2005.
Brazilian fuel is a mixture of gazoline, ethanol and many other odd substances, including chit.
This horrible mixture corroded my carburetor and the fuel pump in a question of months, causing erratic function of the motor. Is there a brand of carburetor I could use with this fuel?
99yam40
Re: Carburetor corrosion
I have always heard the there are a lot of Buba's in the south but did not realize they were that far south.
I think you are out of luck with finding a different type of carb for your fuel, but I could be wrong.
From what I understand these motors are not designed to run on that type of fuel, see if you can find fuel that is 10 or less percent ethanol.
buba
Sorry 99yam40
This is not my real name
