Fishsqueezer
Thread starter- Joined
- Apr 5, 2012
- 28
The Engine: I have a 1984 Mariner 50 hp 4 cyl. electric start outboard, serial # 6542853. It has dual carburetors, an upper and lower, each having an integral fuel pump. The upper crab is stamped WMA 3-1 and the lower is stamped WMA 3-3.
The Problem: When I prime the engine by squeezing the in-line pump bulb, fuel shoots forward out of the upper carburetor. It?s coming from a small brass screw with a hole in the center (see image). I know that the pump bulb should become firm once the engine is adequately primed, but this never happens. Instead, the carburetor squirts out copious amounts of fuel which pool up inside the cowling.
I have the Clymer shop manual for this outboard which lists these possible problems in the troubleshooting section under ?Flooding @ carburetor?
-choke out of adjustment
-high float level
-float stuck
-excessive fuel pump pressure
-float saturated and beyond buoyancy
Unfortunately, the Clymer manual images are not congruent with my carburetor and I?m not even sure what the piece is called which keeps squirting gasoline.
What is the brass screw/hole I?ve pointed at in the photo called? I can?t seem to match it to anything in the Clymer book?s diagrams except that it maybe kind of looks like a jet, but I?m not sure. I removed it, and it?s simply a short brass flat head screw with a hole bored through the center.
Any ideas on why the carb is hemorrhaging gas out of this opening? Any help would be much appreciated.
-high float level
-float stuck
