I am loosing 1000 rpms (getting 4500, should be 5500). Traced to the following:<br />Pulled one spark plug at a time, one cylinder not firing. Pulled wire, getting spark, pulled plug and held to metal, it is firing. Looked at carbs, I can see gas spraying from 3 out of 4 carbs. Opened bottom plug on carbs, gas flows from 3, not from the 4th. Any ideas as to the next step I should take?<br /><br />Thank you!
