1994 Mariner 40 HP, 4 cylinder, Serial number OD295837, Dual Carb.
Removed and cleaned (did not replace any parts) carb parts in gunk this spring because of starting problems. Had to set the idle/mixture screw all the way in to keep motor idling. And also have set screws to a richer setting to make outboard run.
Recently have rough starts and cannot put into gear without stalling, have a lot of gas/oil coming out exhaust.
Can run at high idle, so I dont think it is a fuel pump problem ?
I recently puchased 2 carburetor kits and plan to breakdown and install with new parts.
The primer bulb is hard when squeezed. When I lift the primer bulb above the height of the gas tank, air flows back into the gas tank and the bulb is soft. Is this normal?
I have a fair amount of Oil/Gas dripping from carbs. Is this normal?
Am I pointed in the right direction with the symptoms that I have described? any suggestions?
The kits include most everything, with the exception of the floats, they looked to be in good condition. Why should the floats have to be replaced?
Thanks for your help.
Jim
Jim
