Carburetor question for a 1986 Mercruiser 3.0 Litre
adcampbe
My service manual references two mixture screws. I can only see one. Should I be seeing two? I have uploaded a couple pictures.
carb 2.jpg ​​​​​​​
Scott06
Single idle adjustment screw means you have a Mercarb vs the Rochester 2 bbl service manual you are looking at. Very similar carbs as they have a common lineage and the single idle mix screw works the same . Float levels may be different so if you are doing a full carb service might want to find the right manual. This show set up specs
http://www.carburetor-parts.com/assets/images/K529.pdf
