Carburetor rebuild 1974 50hp float question
redfish228
I am rebuilding my carburetors on a 74 50hp. I have a Clymer manual and it says I need to use a float gauge to get the float level correct. My question is, how critical is this and if so where can I get one of these gauges or is there an alternate means?
JHar
Re: Carburetor rebuild 1974 50hp float question
I believe if you install the float and invert the carb, if the float is parallel and even with the carb body you are in good shape.
steviecops
Joe Reeves put a thread on here about setting the float level without a gauge. I would imagine a search would turn it up.<br /><br />Good luck<br />Steve
papasage
JHar is right on the float setting . that is the way i set mine
