carburetor sight tube replacement
nateo
Mine is real grungy and cant see through it. Anything special about it or can i just replace with clear pvc tubing from box store? If so anyone know the size?
achris
More fish than mountain goat
Re: carburetor sight tube replacement
Nope, gotta be 'tygon' tubing.... Size is 'long enough to reach from the fuel pump to the carb'.. ;)
Chris.....
Speakrdude
Ensign
I burnt a buddies motorcycle to the ground when we were teen agers using regular ole clear tubing for the fuel line.
nateo
I can't image he was too happy
998cc
Can a marine-rated inline fuel filter connected with USCG approved fuel line be used as a sight glass in lieu of the Tygon tubing?
achris
Can a marine-rated inline fuel filter connected with USCG approved fuel line be used as a sight glass in lieu of the tubing?
As long as it's not in the engine compartment, yes. No glass 'sight bowl' is allow in the engine compartment due to the likelihood of breaking in the event of a fire.
Chris......
998cc
Chris; I went back to the Moeller page and in the fine print it confirms what you stated above. I assumed that a "Marine" product was listed for any marine use in any location. Thanks for that info! Is there any other product listed for that use or is the "Tygon" the only product to use? It just doesn't "look" like it is up to the task..... I have seen materials that look similar that literally decompose after a few weeks contact with gasoline/petrol.
Thanks.
Russ
achris
Tygon is a product name. We use it on our equipment offshore, for carrying hydraulic oils.
Here's a link to the rating by the C.A.R.B. Tygon tubing - Wikipedia, the free encyclopedia
The other thing to remember, while tygon is rate to carry fuel, in this case it should only have fuel in it when the fuel pump diaphragm ruptures. Other than then, it should be empty....
Chris.......
ktbarrentine
The correct tube is a bit pricey, but I don't scrimp on things that go in the engine compartment. Order it online, get it delivered to your house, put it on... and have no worries.
nateo
Chris.......
Do they often fog up over time or is likely a sign that there is fuel in there?
ktbarrentine
mine turned yellow with age. I replaced it when I replaced my fuel pump after the tube did its job to direct fuel to the carb when my fuel pump diaphragm cracked (damn ethanol fuel!). Didn't really "see" fuel in the tube, but saw it coming into the carb airhorn while troubleshooting a flooding problem.
Bt Doctur
try a lawnmower shop ,they might carry the type needed
