Re: Carburetor trouble
If you want it clean you need to take it apart and clean it, it is the ONLY way to be sure it is done right.
Jets should have a stranded copper wire run through them even if they "look" clean also run wire through carb passages and use compressed air to clean them, the air in a can works well.
As stated, carb cleaner doesn't have any oil in it and is very hard on the engine of coarse bench cleaning use all you want.
There is no genie in a bottle that will clean carbs, do it right once, use a fuel filter and drain the float bowl in the off season and you shouldn't have to do it again for a long time.
