Carburetor
Aaronjohnson9.9
I have a 95 9.9 Johnson j10reoe was told I can put 15 Johnson carburetor to make a 15 horsepower is this correct and if so what years will work and is it just the carburetor I would need or is there other parts that would be required thanks
Aaronjohnson9.9
What do you mean not the whole story,I’m simply asking a question and if you cannot answer it than move along thanks I do not want to purchase another outboard as I already have this and if it is as simple as a carburetor change then why not
jakedaawg
You were told a story, not the whole story. It takes more than a carb. If you want a 15 buy a 15. But since your gonna be a prick, shove off.
Aaronjohnson9.9
Ok thanks I took your comment the wrong way my appologies I didn’t think you were trying to help and HD thought you were just telling me to buy a 15 if that’s what I wanted thank you for the interest stating that it take more than the carb sorry once again like I said I don’t think you were trying to help
Aaronjohnson9.9
I didn’t think you were trying to help*
jakedaawg
No worries, I could have been more clear...long day upside down in the bilge of several boats...
Sea Rider
Used to have an Evi 96 which was converted from a 9.9 to a 15 HP one, aside the 15 HP carb swap, per factory recommendation also swapped the complete reed valve assy which has larger orifices and side gaskets as well due to breaking them when removed. Being my ex motor and yours close years check with a parts manual if there's a 9.9 and 15 HP reed valve assy for that model year.
Happy Boating
Aaronjohnson9.9
Happy Boating
Perfect thanks for the info
jakedaawg
I believe the biggest difference is port timing in those models. About .100". We used to run the blocks on some kneelers. The 15s were always faster and higher r's.
oldboat1
Guess you could try switching for a 15 carb. If happy with the switch, call the operation successful.
Sea Rider
If only swapping just the carb, go for a prop maximization to less prop pitch to pull wot revs up to max wot rmp range. Will better the current hole shot and achieve a slight more top end speed. Must install an induction tach for that purpose. Check here at Iboats store how many less prop pitches from current one installed are available for the Evi 15 HP.
Happy Boating
