I set up a test bench:
- Attached each carburetor directly to the fuel tank (one at a time) and pumped the primer/hand pump ? no gas came out of the carburetor inlet needles.
- Note, I clean the carburetor and flushed them with carburetor cleaner. The carburetor cleaner flowed through the carburetor good; however, when I put them on the test bench ? no gas flowed through the carburetor inlet needles
after I pumped the primer/hand pump.
