Carburetors exchangeable?
jvstream
Will the carbs off a 2003 125hp mercury work on a 1995 125 hp mercury?
jvstream
Re: Carburetors exchangeable?
I soaked the carbs overnight in Berrymans Carb Cleaner as advised by a boat mechanic. For some reason (inferior parts, soaked too long?) this damaged the brass components on all four carbs. I have aquired four carbs off of a 2003 Mercury (same hp). If they fit do you believe they would work. What type of adjustments might be required elsewhere on the engine? Thanks for the help!
