Carling Contura wiring for dual fuel tanks on a single guage
airslot 18.5
Hi all,
I want to wire dual fuel tanks to a single guage using a Carling double pole? rocker switch. It has the 7 seven terminals on the back. I am unsure where to wire the 2 seperate signal lines from and to the guage.
Please help!
thanks
Silvertip
Re: Carling Contura wiring for dual fuel tanks on a single guage
Here ya go. If you already have the switch use it but you only need to use one side of it. The seventh terminal on the switch is the ground for the internal light. That terminal serves no other purpose than to provide a ground path for the indicator light.
fucawi
Banned
nice diagram what software did you use to draw it .?
Silvertip
Senders, switches, gauges, etc. in all of my diagrams are grabbed from various websites using a very old program called FullShot. It can grab a page, any portion of a page, any item, any buttons on that page, as well as a freehand grab of any portion of the page. Those grabs and other photos are then dropped into Power Point where lines and text is added. Since PhotoBucket requires pictures, FullShot is again used to grab the finished artwork and it is saved in any of the standard formats (JPG, etc.). That image is then uploaded to Photobucket.
airslot 18.5
Thank you so much, you just made life much easire!!!!!
thanks again
