Carlisle Trailer Tires
HalfFish5087
Gents, I have a 226 Larson (3K dry weight) on a tandem roadrunner trailer with ST205/75 D14 tires. According to the previous owner these were bought new about 8 months ago and the condition of the tires appears to reflect this. The tires may have 1,000 miles on them with no cracking, bubbles or any other abnormalities.
Before leaving out this weekend I checked pressure and put all tires at 45 psi. The tires do note 50 psi cold. Here comes the good part, after about the first 5 miles (maybe 15 miles of total travel on the return trip) on the interstate doing 60 ? 65 mph, the left rear tire suffered a blow out leaving some carnage on the wheel well and taking a side bunk with it. I had a spare so the day wasn?t spent on the side of the road and luckily no other cars where close at the time of the blow out. The rear axle is my braking axle and I checked to see the wheel was overly hot and it was warm, but did not appear to be excessive.
I did a quick search and it appears that many others have not had great success with this brand of tire. Can anyone comment on the quality of these tires? Should I have not put 45 psi of pressure in the braking tires since they do heat up more than the non-braking tires? I?m not sure what the tire load rating is, but I will be checking it tonight to make sure I?m not exceeding it. Thanks ahead for any responses.
oldjeep
Re: Carlisle Trailer Tires
Opinions will vary, but my .02 is that you should have had 50psi in the tires. I've had some carslisle tires in the past and didn't find them any worse than others but some say they are worse.
From your picture it looks like the sidewall was rubbing on the fender.
nate1220
I used to work for a tire shop that was a carisle dealer. I run carisle on all of my trailers. I love their tires. If you read the DOT you can figure out the actual age of the tire. Just because they were bought a few months ago doesn't mean the tire isn't a few years old.
HalfFish5087
oldjeep, Thats what I thought at first glance, but there is at least 4 inches between the fender and tire.
HalfFish5087
Seaman, this is the only one I have on me now. Let me know if it has the detail you are looking for. Thanks!
1000 miles can be a lot, or not much at all. if you do a lot of tight backing/turning, etc. then your skidding two of the wheels every time you turn. I used to change the rear axle tires once a year on the searay's shoreland'r trailer because I was cording the tires with the tight turning I had to do to get the boat in the garage. I usually caught the tires when the tread started to get distorted, however not always.
its hard to tell, however sometimes tires fail from underinflation, some times from cord separation, some times from road debris.
H20Rat
My guess is that you may have picked up some debris/nail and ended up with a flat tire. On a tandem trailer you won't notice a problem until you see chunks of rubber flying up in the mirror. (on a single you would have felt a flat tire)
oldjeep
Tire in that picture looks low - how much pressure is in that one? You have to be really carefull on tandems, when you are making a tight turn you can easily damage/ shred underinflated tires due to sidewall flex
bigdee
Can you post the D.O.T. Info? Also tires should always be inflated to max. People seem to be paranoid about this but tires are not balloons, they need to be rigid to be safe.....flex on trailer tires is not good. True,tires may heat up from various factors and increase pressure above max but this is normal. The specs on the sidewall are for cold tires.
royal0014
This ^^ is my thoughts. Can you see the trailer wheels in your rearviews? And how often do you look?
HalfFish5087
Know that I think about it, the boat did seem to pull a little heavier when I pulled onto the interstate and I'm guessing that smokingcrater is correct in that I did likely picked up something and the tire went flat before becoming a road gator.
I do try and check the tires in the mirrors every few minutes, but of course I can only see the front set so...
Thanks for all the responses and I will still try and post the DOT info tonight.
oldjeep
ST205/75 D14 would normally be 1760lbs at 50psi (x4 = 7K total) Highly doubtful that he is overloaded.
royal0014
Yep, there's your clue. Make sure you double-check the wheel bearing where that tire was.
greekfreek
50Lbs is correct. However a rep from EZ Loader stated to me that "Carlisle recommends when going 66 to 75mph that the inflation should be increased by 10lbs. I could not fine this anywhere on the Carlisle web site and I sent them an Email, no answer as of yet...
kenmyfam
I am thinking they should be at 50 psi cold to begin with. Would take out some of the "if's" in the diagnosis.
greekfreek
Well Carlisle responded to my question of tire pressure at speeds 66 to 75 mph. "The pressure should be set to whatever is on the sidewall" So thanks EZ Loader for wrong info.
dingbat
Interesting, seeing that all "ST" tires have a maximum speed rating of 65 mph
