carpet adhesive on treated lumber
Russdog
I'm looking for a recomendation on what type of adhesive to use on treated lumber. Most I've seen (Henry's, Roberts) say not to use on treated lumbeer.
Suggestions?
Yacht Dr.
Re: carpet adhesive on treated lumber
Hello Russ..
not only the ply compatible glue..but what does your carpet suggest. ?
Most backed carpets I would suggest Dap Contact cement ( troweled ). some are too thin and use a spray glue ( like 3m trim adhesive in a spray ).
NO MATTER what you use.. Dont be alone ..and wear a respo.
last thing you need is to be overcome with fumes..bad bad stuff here....make you feel your hair grow ...
YD. ... be safe m8 ( fume glues are nothing to mess with ! )
CN Spots
I got mine at Lowe's. Outdoor carpet cement. Black can. I can't recall the name.:confused: If the wood is really wet it will take a long time to dry.
and yeah, a good whiff and you'll have a headache for days.
ebuhr
I got mine at Lowes also. Mine was in a white gallon bucket. I used it on PT plywood that was still wet. Took a while to dry. Once it dries it holds very well. I used it on a small section of flooring in my boat. It was a quick fix using cheap carpet last summer. I decided to fix it right this spring. Had to use a grinding wheel to get the carpet off.
5150abf
I build pontoon boats and we use sommething that looks and smells just like Elmers glue, it comes in a giant cube probably 80-100 gallons so I don't know a brand name but you can glue treated wood.
I have used the trowel on outdoor carpet glue from Lowes/Menards on marine ply and it worked really well.
What is up with all the Indiana boaters on here all of a sudden, never noticed alot of Hoosiers before.
