Re: Carpet Replacement - How Hard? Any Tips?
I replaced the carpet in my fish-n-ski a few months ago, kind of wish I'd have had some help from someone who'd done it before. It didn't turn out perfect, but it's acceptable (and a far cry better than the tattered stuff that was in there when I bought the boat).
There are a few websites that give an overview of how to do it, they cover it pretty well. You've got to make sure that all the pieces of carpet are lined up in the same direction because the 'grain' will show. I found it easier to make templates for EVERYTHING, then double and triple check for fit before cutting the carpet. Then after using the templates to make your cuts, lay the carpet out and check for fit again. And don't get in a rush when putting down the glue, you've got plenty of working time with it.
That's about all the little gotcha's that I learned the hard way. It can definitely be done by a good do-it-yourselfer, but you probably won't get quite the results of taking it to a professional (won't lay out nearly the cash either).
