Carpet Ripping, Can I hammer this in or could it cause leak?
jabroni1m
stevenj
Re: Carpet Ripping, Can I hammer this in or could it cause leak?
I would take a file to it rather than hammer on it.
jabroni1m
A file sounds good. Below that weld spot isn't part of the air chamber is it? THanks for any information.
Jeff-in-PA
The file will probably clog with metal filings. Simply take a wire brush and brush the chips out of the file teeth. Follow the same angle as the file.
D
DJ
Guest
That is a keel. It is there to provide some protection for the tubes and give some lateral stability. It is not part of the sealed tube.
File it.
