Mel Taylor
- Joined
- Jun 25, 2009
- 489
I have a 14' Mirrocraft with a tiller steered 30 HP Evinrude on it. It has full bench seats front and rear. Where the third (center) bench seat would normally be, there is a tool box on each side with a "walk through" opening in the middle . Sides of the bench seats go nearly to the floor.
I carry a full length paddle in the boat but regardless of where I put it, it always seems to be in the way. I usually lay it lengthwise in the floor in the center of the boat, but when I stand up to cast, there it is, under foot. I can put one end on the rear seat and the other end on one of the tool boxes, alongside the gunnels, but it's even more in the way there and tends to fall off one end or the other when underway at high speeds.
It cannot go crosswise behind the rear seat because floatation chambers on each side take up too much room.
It looks like the best place would be to mount some kind of bracket on the front of the rear bench seat to hold the paddle. Only trouble with that might be that the back of my legs, when operating the boat, would be next to, or against, the paddle and brackets. In other words paddle and bracket probably shouldn't stick out too far.
I know I cannot be the only one who has run into this problem so I'm betting that someone in this forum has done it before and can come up with a solution.
I'm open to any and all suggestions and ideas.
