Carver 250 Mid Cabin Cruiser - Water Leaking from Thermostat Housing
Trooper583
I brought my In-law's Carver 250 Mid Cabin Cruiser out of winterization today. It has the Mercruiser 7.4 Liter 454. The engine started without any problem and idled very well. Thinking that this was the first time the boat had been ran in several months, I decided that I should open the hatch and make sure everything was looking ok as it warmed up. As I watched it, I noticed a small trickle of water coming from the thermostat housing area. I had just started the engine and it wasn't even close to operating temp.
I have a lot more experience with simple open bows as opposed to cruisers so maybe you guys can help with this. It appeared that there was a small hose, (maybe .5 inches I.D), that runs from the thermostat housing to the hot water heater. the water has a very steady leak / stream from where the brass fitting threads into the engine block or somewhere in this area. I checked the hose clamp and it is secure. What would you all check first?
A marine service company unwinterized it a few days prior which was worthless because they couldn't get the engine to turn over. (didn't turn the battery switch on :)
Thanks in advance for the replies.
Navigator_Victory
Re: Carver 250 Mid Cabin Cruiser - Water Leaking from Thermostat Housing
My twin......I have the 5.7 so not sure if the setup is the same...sure Don will pop on here anytime and ask you more questions.....I have found it seems better if you take a picture of exactly what is screwing up.....just guessing I would check the hose and where it feeds into the block first...I am really to new to be good for advice but,,,,,I can at least pop this back to the top by commenting :)
Trooper583
Thanks. I almost took a picture today but was running short on time. In reference to the threaded fitting in the block...it has some type of white sealant on it. Would that just be gasket maker?
Trooper583
Like I said, I was running out of time the other day. I should have made sure that the marine service company replaced the hose properly. A small portion of the hose was rolled up under the fitting, causing s small stream water. That's the last time we'll use them...
