Carver 35 SS - Stern Thruster
adcohen91
Hi,
My stern thruster has stopped working. I have verified the battery is OK and I'm getting power to the joystick, but it doesn't operate the motor. Any clue where else I should look.
Fireman431
Re: Carver 35 SS - Stern Thruster
Use a test light and see if you're getting power out of the joystick when you move it. Then check to see if you're getting power to the motor while someone works the joystick. If it died over time, the motor probably gave out. If it died suddenly, then one of two things happened.
If it died while you were using it, then you may have overheated it and tripped a relay. If it just "didn't work" one day, then you may have blown a fuse. Check first for bad grounds or corroded connections.
